Basic Default Route Question
I have a very basic question I wanted to run by everyone to make sure my understanding is correct.
Setup:
Basic config, router with two interfaces and a single default route.
hostname RTR1
interface Ethernet0/0
ip address 1.1.1.1 255.255.255.0
interface Ethernet0/1
ip address 1.1.2.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 1.1.2.2
add -> ip route 0.0.0.0 0.0.0.0 10.10.10.1
If I add a default route (currently in a telnet session coming through 1.1.2.2 to get to RTR1) to a gateway that is NOT locally connected nothing will happen, correct? The router won't try to load balance my traffic since the second gateway is not directly connected and reachable, correct?
Next, if I change the IP address on e0/1 to 10.10.10.2/24 then my default route of 1.1.2.2 will no longer be used and my 10.10.10.1 defaut route will become active, correct?
I can then connect using my new IP of 10.10.10.2 assuming all routing is working on my new default gateway, correct?
Basically, I'm making sure my understanding of the default gateway route not being used unless it is accessible is valid. If it is, it will load balance traffic across up to 6 of them.
Please comment or correct if my understanding is incorrect.
Thanks.
Hall of Fame Super Silver
Re: Basic Default Route Question
Jamie
I believe that most of your understanding is ok especially about not load sharing over the routes as defined. I checked it on a router and only the default route with a reachable next hop is inserted into the routing table. Both static default routes are in the config but only one is in the routing table.
Rick
Rick,
Thanks for the reply.
-Jamie
207
