basic eigrp question
Please see the config below. (I changed the ASN and the IP addresses so please don't get hung up on that) My goal is to load balance between FA2/0 and FA2/1, and have my default route (network) be both FA2/0 and FA2/1. If either link goes down, (which happens from time to time) will my eigrp traffic still flow through the other available link without issue, taking into account "variance" and "traffic-share"?
interface FastEthernet2/0
description 100 Mb connection to xxx
bandwidth 100000
ip address 10.1.1.6 255.255.255.252
ip access-group 103 in
ip access-group 104 out
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no keepalive
duplex full
speed 100
no cdp enable
interface FastEthernet2/1
bandwidth 100000
ip address 10.1.1.14 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no keepalive
duplex full
speed 100
no cdp enable
autonomous-system ???
router eigrp ???
redistribute connected
redistribute static
network 192.168.0.0
network 10.1.0.0
distance eigrp 9 10
variance 2
traffic-share balanced
no auto-summary
eigrp log-neighbor-changes
ip default-network 10.1.0.0
Bronze
Re: basic eigrp question
The configuration seems fine. The load balancing should work in this case.
However, I guess the ip default-network works in a classful manner.
So the command given should be ip default-network 10.0.0.0. Refer to this doc for the details.
http://www.cisco.com/en/US/tech/tk648/tk365/technologies_tech_note09186a0080094374.shtml#ipnetwork
In the scenario given by you, load balancing would work without the variance command also, since both the links have the same bandwidth.
Thanks for your reply. I was beginning to wonder if was that basic of a question that no one wanted to give a reply ... haha.
You are right about the ip default-network command. My default network is actually a class "B" address. As I stated, I changed the IP address for security issues. So I would have xxx.xxx.0.0 for my default route. That is a very good catch. Thanks for the info on the variance command as well.
81
