06-19-2002 10:16 AM - edited 03-01-2019 10:17 PM
Can some one tell me how I should configure my router using frame to pass traffic transparently... I will be using a Cisco 1720 with a dedicated 128k frame on s0/0 connected to a NetScreen (for firewall and VPN) via e0/0. I built the bridge-group and corresponding PVC in our MAIN ROUTER just like I would for a DSL PVC. This is what is on the main router sub-interface to connect to the 1720 (CPE).
interface Serial0/0.47 point-to-point
description Bla Bla Bla
bandwidth 128
no ip route-cache
no ip mroute-cache
frame-relay interface-dlci 78
bridge-group 3
interface BVI3
description NON-DSL Frame-Relay Connectivity
ip address 4.x.x.x 255.x.x.x
This is my main Serial Interface for these subs:
interface Serial0/0
description connected to Frame-Relay Cloud
no ip address
encapsulation frame-relay IETF
no ip route-cache
no ip mroute-cache
keepalive 12
no frame-relay inverse-arp
frame-relay lmi-type ansi
This is the current 1720 (CPE) config (not completed I assume for this scenerio to work...):
interface Serial0
no ip proxy-arp
no ip route-cache
keepalive 12
no fair-queue
service-module t1 timeslots 1-24
service-module t1 remote-alarm-enable
interface FastEthernet0
description IPS Gateway
ip address 10.x.x.x 255.x.x.x
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 4.x.x.x
What should the 1720 config look like for the it to be nothing more than a terminator for the Frame-Relay coming in, as if it were a DSL modem.
Josh
06-19-2002 12:40 PM
The config should not be similar to DSL, where you would be bridging the data over the ethernet. Instead, you should be able to route all IP on the 1720. Add an IP address to the sub-interface, confirm that the PVC is up and active (sh fr pvc), and you should also consider enabling fast-switching. Packets should then be able to pass from the ethernet interface to the FR network, and vice versa.
06-24-2002 12:38 PM
Thanks for your reply. However, the frame relay connection at the remote site is mapped via DLCI to a PVC in the main router. The main router already takes care of 47 DSL clients. The 1720 is to terminate a dedicated Frame Relay (point-to-point) back to the same serial interface that is "subbed out" for DSL. I would like a suggestion as to how to make the 1720 as transparent as possible in this configuration so that the firewall/VPN device behind it will not be NATed. Thanks again.
Josh
06-25-2002 11:31 AM
Just need to get back to the top of the posts, at least the first page. Got pushed back 3 pages. Need help... Thanks.
