Basic Routing issue
I have 2 routers with a pix in the middle, the pix has an ip of 192.168.1.7 there is then a VPN connection to a remote site with the address range 192.168.254.0
I have added the route as shown below for the 192.168.254.0 network and I can ping Servers on the network from the Router but not from a client on the LAN (address range 192.168.0.0). I know this is basic but my tired mind is getting annoyed! Help!
interface FastEthernet0/0
ip address 192.168.0.254 255.255.255.0
ip access-group 102 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
ip address 192.168.1.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip ips sdm_ips_rule in
ip route-cache flow
duplex auto
speed auto
no mop enabled
ROUTES
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 192.168.254.0 255.255.255.0 192.168.1.7
Re: Basic Routing issue
What are the Access-List Entries for "ip access-group 102 in" on Fa0/0. Are you allowing traffic from 192.168.0.x to go to 192.168.254.x.
And can you post the full configuration. Make sure that you remove all sensitive information, like passwords and public IP's before posting the configuration.
Arul
In addition to checking the ACL, can you check whether the router or layer 3 device at the remote site has a route to get to the 192.168.0.0/24 network.
Sundar
87
