Webcast-Catalyst9k
BBSM Bandwidth Settings 768Kbps?
Is it possible to change the bandwidth selections per user which are currently 64, 128, 256, 512 and full speed to custom settings such as 768?
Ted
1 REPLY
Re: BBSM Bandwidth Settings 768Kbps?
I found the solution if anyone is interested.
Modification to portForm.asp will accomplish this. It appears that there will be a site index at the end of this file name if the site is already configured in the BBSM. Here is what my file contained after modification in which I added 768 and 1536 at the end:
Bandwidth Per User
<% if (strBandwidth == null)
Response.Write("");
<%=( (strBandwidth == "0")? "selected" : "" ) %> value="0">Full-Speed
<%=( (strBandwidth == "512")? "selected" : "" ) %> value="512">512 Kbps
<%=( (strBandwidth == "256")? "selected" : "" ) %> value="256">256 Kbps
<%=( (strBandwidth == "128")? "selected" : "" ) %> value="128">128 Kbps
<%=( (strBandwidth == "64")? "selected" : "" ) %> value="64">64 Kbps
<%=( (strBandwidth == "768")? "selected" : "" ) %> value="768">768 Kbps
<%=( (strBandwidth == "1536")? "selected" : "" ) %> value="1536">1536 Kbps
-Ted
84
