Beginner to VLAN Pl Help
Hi Friends,
I am asked to create VLANs on L2 Switches 2950 Model. IOn a Test Switch Ientered into interface mode and given the below Command on one of the ports.
The test Switch is Uplinked to our live Network from a Series of Switches which are not in VLANs.
Switch2(config-if)#switchport access vlan 10
I attached a workstation to VLAN 10 port. I am not able to ping my Network.
on Other Ports of the test Switch I am able to Ping.
I also created a secondary interface on My Router Running Eth Port and kept the WOrkstation in the same subnet of the secondary interface created n the Router. My gateway entry on W/S is also Correct. I am missing some thing I beleive. Can any one pl. help me.
Rgds
Srini.
1 REPLY
Re: Beginner to VLAN Pl Help
Have you created VLAN 10 in the VLAN database?
http://www.cisco.com/warp/public/793/lan_switching/3.html#confthevlancat
Also are you trunking on the port which connects to your router which does inter VLAN routing?
75
