Best and secure way to connect 2 cores
yann.boulet
I would like to know the best and secure way to do that :
PIX2 ethernet 0.1 --> Catalyst 3750 --> Catalyst 4006 --> PIX1 ethernet 1.1
the catalyst 4006 is the VLAN manager both of the pix use subinterfaces
for the moment i configured the interface on the 4006 as trunk but i am not really good with prunning allowed vlans
Can you please give some help ?
amit-singh
Level 8
Level 8
Hi friend,
What exactly you want.. you want to connect 3750 and 4006 or is there some other thing.
You have to explain it little more. Its not clear what you are exactly looking for.
-amit singh
sorry because i am french ;) what i want to do is to share only one vlan between the C4006 which the vlans root and the C3750 because i use virtual interfaces on my Cisco PIX's so vlans need to be configured.
What i don't want to do is to allow other vlans on the C4006 to be distribute through the C3750 which has already some vlans that can have the same vlans id.
