03-24-2004 02:18 PM - edited 03-02-2019 02:32 PM
I'm trying to determine what the best router is for doing home hosting/biz.
1721
1712
1711
It seems given my ADSL connection and router from SBC that the 1711 would serve my needs best but the Cisco Small Business Network Designer suggested a 1721.
Anybody have any preferences here and if so, why?
Thanks muchly!
Jon
03-27-2004 03:06 AM
Hi Jon,
I would use a secure PIX 501 or 515 Firewall to do basic routing and establish a DMZ.
R/S
Dave
03-29-2004 03:50 PM
515 for a home buisiness setup? isn't that a bit of an overkill?
what about just doing port forwarding on... say a 831 or something?
lots of people don't like the 800-series devices, but i've never had any issues with them. they're great little boxes.
03-29-2004 05:45 PM
I agree that the 515 is probably overkill for a home based business but if there is going to be a server that customers hit from the Internet I would probably recommend this as well. What else is going to give that 3rd interface to (more) securely hang a web server off of? Some of the higher end routers will but then they are not dedicated to security like the PIX. A low end router like a 1700 series with a PIX behind it would be best in my humble opinion but as you can see by the rankings I am sucking eggs this month! :)
03-30-2004 04:41 AM
what about a 831 w/ the FW feature set, with port forwarding?
can someone explain to me why port forwarding isn't favored over a DMZ? afterall, doesn't a DMZ open everything to outside access, where port forwarding only opens particular ports for access?
03-30-2004 10:29 AM
Thanks for all the replies...good info here. This is what the Cisco Small Business Network diagrammed for me:
It seems like the 1721 is the way to go and from folks to talked to at Cisco the firewall it uses will work well for setting up a DMZ with only one server.
The PIX is a good idea though, I'll have to give it some thought.
Thanks!
03-29-2004 10:29 PM
For home business..you could use a 1700. 1721 is better than the rest probably because it has many supported features which the rest doesnt support. More supported hardware, software features etc.
I would also suggest using a PIX 501 or 506. It can do PPPOE, vpn, provide you excellent firewalling, a 4 port switch on the inside, 10 Mbps connection on the outside. They are cheaper in price too..You wont get a dmz with 501 or 506.
03-31-2004 09:56 AM
Hello Jon,
I have looked at these routers and I will be using a Cisco 1711 for my business. It uses a Firewall and IDS IOS. IT can terminates VPN. It is also a switch with 802.1Q vlans.
For a small business, it is a lot in 1 device.
Nadine.
