01-31-2002 03:41 PM - edited 03-01-2019 08:19 PM
I need some advice on the best method for BGP routing. Currently I think I am receiving the full table from both my upstream providers and I think this is causing my 3640 to reboot for lack of memory. It has 128megs. I inherited a real messy config and would like to clean it up. I want to advertise two more routes also. I currently have 8 class c's that I am advertising. Is there an alternative to this? Just receive upstream providers routes?
Thanks for any help.
01-31-2002 07:39 PM
You should send your routing to service provider and
service provider should block all routing to send to you.
router bgp A
no synchronization
network 172.16.10.0
neighbor 192.168.2.3 remote-as B
neighbor 192.168.2.3 ebgp-multihop 10
neighbor 192.168.2.3 update-source FastEthernet0/0
neighbor 192.168.2.3 distribute-list 40 out
neighbor 192.168.2.3 filter-list 1 in
neighbor 192.168.20.3 remote-as C
neighbor 192.168.20.3 distribute-list 40 out
neighbor 192.168.20.3 filter-list 1 in
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 Serial2/0
ip route 0.0.0.0 0.0.0.0 Serial2/1
ip route 172.16.10.0 255.255.255.0 Null0 200
no ip http server
ip as-path access-list 1 deny .*
access-list 1 permit any
access-list 40 permit 172.16.10.0 0.0.0.255
access-list 40 deny any
This configuration block all routing ...
and should use the same at service provider site
02-01-2002 06:57 AM
Try looking this paper, it shows how to Receive Full Internet Routing Table, Receive Directly-Connected Routes and Receive Default Routes Only from your providers.
http://www.cisco.com/warp/public/459/27.html
Mauricio
02-04-2002 08:57 AM
you can implement ip aspath access-list using which you can restrict updates to your router from your upstream provider.All you need to do is associate a route-map for incoming advertisements with the ip-aspath access-list.
Best Regrads
kanwal
02-04-2002 12:12 PM
If you are having two different Upstream Providers, then there is an option from both service providers to send not FULL but PARTIAL routing tables to you. I suggest you to try atmost to not implement routing restricting policies at your end, because that will cause some increase in overhead of your router to see every route and comparing.
And also dependent upon Bandwidth capacities of both carriers, you can take FULL from one BIG and PARTIAL from another provider.
Regards...
--Ashok.
02-04-2002 03:33 PM
Thanks for all your suggestions. Here is a config I came up with. If anyone would care to review and let me know how it looks that would be great. Load sharing and default routes only are my goals for this config.
interface Serial0/0
description Provider A
ip address 10.10.10.10 255.255.255.252
no ip directed-broadcast
(add no ip route-cache?)
interface Serial0/1
description Povider B
no ip address
encapsulation frame-relay
frame-relay lmi-type ansi
interface Serial0/1.16 point-to-point
ip address 20.20.20.20 255.255.255.252
frame-relay interface-dlci 16 IETF
router bgp 12345
no synchronization
network 64.240.108.0
network 64.240.109.0
network 199.217.73.0
network 207.138.224.0
network 206.129.32.0
network 207.138.233.0
network 207.149.12.0
network 209.102.32.0
network 209.102.33.0
neighbor 10.10.10.20 remote-as 1234
neighbor 10.10.10.20 description Provider A
neighbor 10.10.10.20 route-map localonly out
neighbor 10.10.10.20 route-map UPDATES-1 in
neighbor 10.10.10.20 prefix-list ABC in
neighbor 20.20.20.20 remote-as 2678
neighbor 10.10.10.20 description Provider B
neighbor 10.10.10.20 route-map UPDATES-2 in
ip prefix-list ABC seq 5 permit 0.0.0.0/0
route-map UPDATES-1 permit 10
match ip address 1
set weight 100
route-map UPDATES-1 permit 20
match ip address 2
route-map UPDATES-2 permit 10
match ip address 1
route-map UPDATES-2 permit 20
match ip address 2
set weight 100
access-list 1 permit 0.0.0.0 127.255.255.255
access-list 2 deny 0.0.0.0 127.255.255.255
access-list 2 permit any
end
