best practice connect 2 full data T-1 from point to point
I have a 3640 12.2(21) and a 3725 12.3(5). I want to conect the 2 point to point T-1s as multilink PPP. I want to see if I can make 2 1.5 MB pipes act as 1 3 MB pipe. I have asked this before.I have a sample configuration see http://www.cisco.com/en/US/customer/tech/tk713/tk507/technologies_configuration_example09186a0080093d69.shtml. Will this work?
The config Current configuration!version 12.2!hostname Router1!!username Router2 password 0 abc ip subnet-zerono ip domain-lookup! multilink virtual-template 1!--- Applies the virtual interface template to the multilink bundle interface Loopback0 ip address 192.168.10.2 255.255.255.0 !--- The loopback address is used by virtual-template 1 interface Virtual-Template1!--- Interface virtual-template is a logical interface which creates!--- Virtual access interfaces dynamically and applies them to !--- physical serial interfaces ip unnumbered Loopback0!--- Always unnumber the virtual-template to an UP interface
!--- Do not assign a static IP ppp authentication chap ppp multilink !--- Enables multilink ppp on the virtual template interface interface Serial0 no ip address encapsulation ppp pulse-time 1 ppp multilink!interface Serial1 no ip address encapsulation ppp pulse-time 1 ppp multilink!!ip classless!line con 0line aux 0 transport input allline vty 0 4 login!end
Router2 - Cisco 2503
Current configuration :!version 12.2!hostname Router2!!username Router1 password 0 abc ip subnet-zerono ip domain-lookup!multilink virtual-template 1!!!interface Loopback0 ip address 192.168.20.1 255.255.255.0!!interface Virtual-Template1 ip unnumbered Loopback0 ppp authentication chap ppp multilink!interface Serial0 no ip address encapsulation ppp no fair-queue clockrate 56000 pulse-time 1 ppp multilink!interface Serial1 no ip address encapsulation ppp no fair-queue clockrate 56000 pulse-time 1 ppp multilink!!ip classless!!line con 0line aux 0line vty 0 4!end
Re: best practice connect 2 full data T-1 from point to point
A simpler config for 12.2 can be like this:
RouterA:
interface serial1
no ip address
encapsulation ppp
ppp multilink
multilink-group 1
interface serial2
no ip address
encapsulation ppp
ppp multilink
multilink-group 1
interface multilink1
ip address X.X.X.X X.X.X.X
ppp multilink
multilink-group 1
And the corresponding config on the other side.
This will be easier that with the virtual-access interfaces.
Regards.
Thanks.....will this provide for redundency and most importantly allow the two 1.5 mb pipes to act as one 3 mb pipe????
Yes, it should ;)
104
