Best way to connect
What would be the best way to connect two switches to a router in order for both switches to have the same bandwidth and speed?
1 REPLY
Re: Best way to connect
Are both on the same subnet or different ones? If same, probably daisy chain them off the router. Assuming you have 100MB connections, that's probably about as good as you can hope for. If two different subnets, and two different router interfaces, hook one up to each interface.
117
