08-08-2002 05:00 AM - edited 03-02-2019 12:32 AM
f I aggregate 192.168.0.0 255.255.0.0 as-set
(one specific route with community no-export another with no-advertise)
will the aggregated route with community no-export or no-advertise ?
08-08-2002 10:51 AM
rfc1997 reads:
If a range of routes is to be aggregated and the resultant aggregates attribute section does not carry the ATOMIC_AGGREGATE attribute, then the resulting aggregate should have a COMMUNITIES path attribute which contains all communities from all of the aggregated routes.
In your case, the use of 'as-set' should result in not carrying the ATOMIC_AGGREGATE attribute...so all the communities should be present.
In the specific example, no-advertise would take "priority" (because it includes the no-export semantics) in terms of operation.
08-09-2002 05:05 PM
Thanks a lot.
but can I consider that a bgp route with multiple well known communitis will prefer no-advertise than no-export than none ?
And another maybe infant question for consult: for example:An border router receive an ibgp learned route with local_pref is 100 and the same prefix learned from EBGP with none local_pref ,will the local_pref be exclude outside the processing decide for this prefix?
sun
08-12-2002 03:41 PM
I believe the IBGP route will be preferred in this case due to the higher local preference.
