Webcast-Catalyst9k
Bronze
bgp and traceroute
Hi all,
I am having multiple internet providers and running BGP with all of them.
Traceroute packets are ping packets with incrementing TTL value. I can know the forward path from my client to the destination i.e ping request path. But i am wanting to know the ping reply path i.e the reverse path from the remote client to reach to me. Elaborately, i want to know the reply is coming through which of my internet provider.
Thanks in advance..
Regards...
--Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
Re: bgp and traceroute
There is no reverse traceroute you can do.
Only way to check is "debug ip packet detail"; which ingress interface the packet arrived to you, in that way you know which ISP path did it take to enter your router.
eg;
ping reply packet from source 10.64.79.41 below is entering my router using ingress interface FastEthernet0.
2d00h: IP: s=10.66.79.41 (FastEthernet0), d=111.111.111.111, len 100, rcvd 4
2d00h: ICMP type=8, code=0
2d00h: IP: s=111.111.111.111 (local), d=10.66.79.41 (FastEthernet0), len 100, sending
R/Yusuf
There is no reverse msg traceroute.
But why not use a agent capturer at remote site LAN and grab the icmp reply
packets sourced from remote site?
Hi.
You can try to use the "record route" option.
Hope this helps.
NM
421
