BGP attributes LOCAL_PREF and MULTI_EXIT_DISC
I have a very basic setup. two routers connected together via two links (one short hall ethernet circuit and one E1 between sited)
Running IBGP peering over both links. Both neighbors has route-maps with the setting for clarity.
If I do nothing, RTR2 to get to iBGP learned routes behind RTR1 will use the serial-link as the neighbor IP address is lower.
Now, I thought I may have two options to either set the MED (metric) or the local_pref with a route-map on RTR1 outbound to RTR2, but the MED option does not work. It sets the MED on rtr2 but the BGP table still uses the serial.
WILL MULTI_EXIT_DISC work with iBGP links? like I say, the values in the iBGP table on rtr2 reflect the route-map setting the MED which is config'd on RTR1.
CONFIG on RTR1 (no config for attribs on RTR2)
-------------SET-MED---------------------------------
router bgp 65001
neighbor 3.3.3.2 remote-as 65001
neighbor 3.3.3.2 route-map SET-MED-ETHERNET out
neighbor 2.2.2.2 remote-as 65001
neighbor 2.2.2.2 route-map SET-MED-SERIAL out
route-map SET-MED-SERIAL permit 10
match as-path 11
set metric 1000
route-map SET-MED-SERIAL permit 20
no route-map SET-MED-ETHERNET
route-map SET-MED-ETHERNET permit 10
match as-path 11
set metric 500
route-map SET-MED-ETHERNET permit 20
or
-------------SET-LOCALPREF---------------------------------
router bgp 65001
neighbor 1.1.1.2 remote-as 65001
neighbor 1.1.1.2 route-map SET-LOCALPREF-ETHERNET out
neighbor 2.2.2.2 route-map SET-LOCALPREF-ETHERNET out
route-map SET-LOCALPREF-SERIAL permit 10
match as-path 11
set local-pref 80
route-map SET-LOCALPREF-ETHERNET permit 10
match as-path 11
set local-pref 90
2 ACCEPTED SOLUTIONS
Re: BGP attributes LOCAL_PREF and MULTI_EXIT_DISC
Yes, MED should work on iBGP links.
What do the routes look like on rtr2?? Keep in mind that the MED is towards the end of the selection process *and* only compared from routes from the same neighbor AS. Either of these two factors may not be letting you reach the comparison point.
OTOH, LOCAL_PREF is compared at the start of the selection process *and* for all paths (regardless of where they came from).
To give you a definite answer, I would have to see the paths as seen by rtr2. If you don't want to post them here, you can send them to me directly: alvaro@cisco.com.
Alvaro.
Please try sh ip bgp filter-list 11 to see whether the routes you want to set MED on match the ip as-path access-list 11.
Ian
Alvaro.
Ian
238
