Community Member
BGP attributs <match tag> and <set metric >
can someone tell me how to use those attributs with cat 6509 (version 12.2 (18) SXD4.
because they don' t run when i try to implement them .
here is an example of the config i try to implement:
route-map metric permit 10
set metric 1
route-map solmetric permit 10
match metric 1
6509-C(config)#router bgp 100
6509-C(config-router)#raddress-family ipv4 vrf vrf2
6509-C(config-router-af)#redistribute connected route-map metric out
6509-C(config-router)#raddress-family ipv4 vrf vrfST
6509-C(config-router-af)#neighbor 210.10.10.2 route-map solmetric in
% "solmetric" used as BGP inbound route-map, metric match not supported %
Thank
1 REPLY
Re: BGP attributs <match tag> and <set metric >
match metric is not supported with inbound BGP route-map. Only the following attributes are supported:
match ip address
match as-path
match community
match nlri
match extcommunity
match policy-list
match mpls-label
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
453
