Webcast-Catalyst9k
BGP - AUTO load balancing - PART1
Say a customer with router RTA is connecting to
a single provider with 2 link ,terminating at
RTB and RTC respectively .
eBGP between RTA and RTB , eBGP between RTA and
RTC .
RTA recieve just a single identical route (say
192.213.10.0/24)from RTA and RTB .
RTA is config with "maximum-path 2" so 2
route to 192.213.10.0/24 will be installed on the
IP routing table .
RTA is config with "Ip 0.0.0.0 0.0.0.0 192.213.10.0)
to point a deafult to network 192.213.10.0 .
The question is how RTA will load balance
traffic destination to the internet (using
the default route ) in the following cases :
Case 1 : Interfaces of RTA toward RTB and RTC are
fast-switching . (Ip route-cache).
is load balancing done on destination-based
or on network based ??
In case it is a network , is it a
classfull network .
Ie: Traffic to any destination
which fall say within class B
172.16.0.0/16 will always go
over a single link .
Case 2 : Interface of RTA toward RTB and RTC are
not fast-switching .
Guess it is packet based .
N.B: The address used above is just for example .
Brgds
1 REPLY
Re: BGP - AUTO load balancing - PART1
126
