BGP Conditional Advertising Question
The not-exist-map feature is intended to allow networks to be conditionally advertised. The examples I have seen use the loss of a network that had been received from remote router A to trigger the start of advertising a different network to router B. I would like to do the reverse. That is, I would like the loss of a network that had been received from remote router A to trigger the end of advertisements of a different network to router B. Is it possible to use the not-exist-map and advertise map tools to accomplish this?
1 REPLY
Re: BGP Conditional Advertising Question
use the "exist-map" instead of "the non-exist-map" on the "neighbor advertise-map" statement to achieve what you want. This feature is available starting with 12.0(15)ST or 12.2(8)T and up.
Hope this help,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
74
