BGP config help
I just turned up a DS3 this morming and need some help configuring BGP. The DS3 is replacing 3 T1's. I will be keeping one T1 for failover. The problem I am having is that right now almost all outbound traffic is going over the T1's I will be dropping and there is a lot of in bound traffic on the T1 I will be keeping for failover. Below is my config. The Savvis T1's will be dropped as will the Global Crossing. Only the Internap T1 will remain.
Mitchel
interface Serial1/0:0
description FRONTIER GLOBAL
ip address 206.165.194.218 255.255.255.252
ip access-group 21 in
ip route-cache flow
ip mroute-cache
interface Serial1/1:0
description Savvis link
no ip address
encapsulation frame-relay
ip route-cache flow
ip mroute-cache
frame-relay lmi-type ansi
interface Serial1/1:0.16 point-to-point
ip address 216.88.192.246 255.255.255.252
ip mroute-cache
frame-relay interface-dlci 16 IETF
interface Serial2/0:0
no ip address
encapsulation frame-relay IETF
ip route-cache flow
no fair-queue
interface Serial2/0:0.1 point-to-point
description Savvis Link 2
ip address 204.194.9.10 255.255.255.252
ip mroute-cache
frame-relay interface-dlci 210
interface Serial2/1:0
description Internap
ip address 63.251.175.178 255.255.255.252
ip route-cache flow
no ip route-cache cef
ip mroute-cache
interface ATM4/0
description ATM connection to SAVVIS
ip address 206.129.33.54 255.255.255.252
map-group ATM_MAP
atm scrambling cell-payload
atm framing cbitplcp
atm pvc 1 5 101 aal5snap 3000 3000 32
no atm ilmi-keepalive
interface FastEthernet5/0
no ip address
ip route-cache flow
ip ospf network non-broadcast
no keepalive
shutdown
half-duplex
router ospf 201
redistribute static subnets
network 64.240.108.0 0.0.0.255 area 0
network 64.240.109.0 0.0.0.255 area 0
network 199.217.73.0 0.0.0.255 area 0
network 206.129.32.0 0.0.0.255 area 0
network 207.138.224.0 0.0.0.255 area 0
network 207.138.233.0 0.0.0.255 area 0
network 207.149.12.0 0.0.0.255 area 0
network 209.102.32.0 0.0.0.255 area 0
network 209.102.33.0 0.0.0.255 area 0
neighbor 207.138.224.8 priority 1
router bgp 13853
no synchronization
bgp router-id 64.240.108.1
bgp cluster-id 3481985278
network 64.240.108.0 mask 255.255.255.0
network 64.240.109.0 mask 255.255.255.0
network 206.129.12.0
network 206.129.13.0
network 207.149.13.0
aggregate-address 64.240.108.0 255.255.255.0 summary-only
aggregate-address 64.240.109.0 255.255.255.0 summary-only
aggregate-address 199.217.73.0 255.255.255.0 summary-only
aggregate-address 206.129.12.0 255.255.255.0 summary-only
aggregate-address 206.129.13.0 255.255.255.0 summary-only
aggregate-address 206.129.32.0 255.255.255.0 summary-only
aggregate-address 207.138.224.0 255.255.255.0 summary-only
aggregate-address 207.138.233.0 255.255.255.0 summary-only
aggregate-address 207.149.12.0 255.255.255.0 summary-only
aggregate-address 207.149.13.0 255.255.255.0 summary-only
aggregate-address 209.102.32.0 255.255.255.0 summary-only
aggregate-address 209.102.33.0 255.255.255.0 summary-only
neighbor 63.251.175.177 remote-as 14744
neighbor 63.251.175.177 description Internap
neighbor 63.251.175.177 version 4
neighbor 63.251.175.177 route-map FROM-INTERNAP in
neighbor 63.251.175.177 route-map TO-INTERNAP out
neighbor 204.194.9.9 remote-as 6347
neighbor 204.194.9.9 description SAVVIS 2
neighbor 204.194.9.9 version 4
neighbor 204.194.9.9 route-map MAP2 out
neighbor 204.194.9.9 filter-list 4 in
neighbor 204.194.9.9 filter-list 1 out
neighbor 206.129.33.53 remote-as 6347
neighbor 206.129.33.53 description SAVVIS DS3
neighbor 206.129.33.53 version 4
neighbor 206.129.33.53 filter-list 4 in
neighbor 206.129.33.53 filter-list 1 out
neighbor 206.165.194.217 remote-as 3549
neighbor 206.165.194.217 description Globalex
neighbor 206.165.194.217 version 4
neighbor 206.165.194.217 route-map MAP1 out
neighbor 206.165.194.217 filter-list 3 in
neighbor 206.165.194.217 filter-list 1 out
neighbor 216.88.192.245 remote-as 6347
neighbor 216.88.192.245 description SAVVIS
neighbor 216.88.192.245 version 4
neighbor 216.88.192.245 route-map MAP2 out
neighbor 216.88.192.245 filter-list 4 in
neighbor 216.88.192.245 filter-list 1 out
ip classless
ip route 0.0.0.0 0.0.0.0 206.165.194.217
ip route 0.0.0.0 0.0.0.0 216.88.192.245
ip route 0.0.0.0 0.0.0.0 Serial2/0:0.1
ip route 0.0.0.0 0.0.0.0 Serial2/1:0
ip route 0.0.0.0 0.0.0.0 206.129.33.53 254
ip route 64.240.108.0 255.255.255.0 207.138.224.8
ip route 199.217.73.0 255.255.255.0 207.138.224.253
ip route 206.129.32.0 255.255.255.0 Null0 254
ip route 206.129.32.64 255.255.255.224 207.138.224.9
ip route 206.129.32.232 255.255.255.248 207.138.224.8
ip route 206.129.32.248 255.255.255.248 207.138.224.8
ip route 207.138.224.0 255.255.255.0 Null0 254
ip route 207.138.224.205 255.255.255.255 207.138.224.38
ip route 207.138.233.0 255.255.255.0 Null0 254
ip route 207.138.233.0 255.255.255.128 207.138.224.8
ip route 207.138.233.80 255.255.255.240 207.138.224.38
ip route 207.138.233.128 255.255.255.192 207.138.224.8
ip route 207.138.233.196 255.255.255.252 207.138.224.8
ip route 207.138.233.208 255.255.255.248 207.138.224.8
ip route 207.138.233.224 255.255.255.240 207.138.224.38
ip route 207.149.12.0 255.255.255.0 Null0 254
ip route 207.149.12.8 255.255.255.252 207.138.224.38
ip route 207.149.12.64 255.255.255.248 FastEthernet0/0
ip route 207.149.12.136 255.255.255.254 207.138.224.38
ip route 207.149.12.137 255.255.255.255 207.138.224.38
ip route 207.149.12.192 255.255.255.252 207.138.224.9
ip route 207.149.12.200 255.255.255.248 207.138.224.8
ip route 209.102.32.0 255.255.255.128 207.138.224.39
ip route 209.102.32.128 255.255.255.128 207.138.224.38
ip route 209.102.33.0 255.255.255.0 207.138.224.8
no ip http server
ip bgp-community new-format
ip community-list 10 permit 65010:400
ip community-list 19 permit 65010:70
ip as-path access-list 1 permit ^$
ip as-path access-list 1 deny .*
ip as-path access-list 2 deny ^6347 3549$
ip as-path access-list 2 deny ^6347_[0-9]*_3549_[0-9]*$
ip as-path access-list 2 permit ^6347_[0-9]*$
ip as-path access-list 2 permit ^6347_[0-9]*_[0-9]*$
ip as-path access-list 3 permit ^3549$
ip as-path access-list 4 permit ^6347$
ip as-path access-list 50 permit _209_
ip as-path access-list 51 permit ^14744_3561
ip as-path access-list 111 permit ^3549.*2554.*$ !PSI group A=2554 Globalex=3549
ip as-path access-list 111 permit ^3549.*6347.*$ !SAVVIS=6347
ip as-path access-list 112 permit ^6347.*$ !SAVVIS=6347
map-list ATM_MAP
ip 206.129.33.53 atm-vc 1 broadcast
access-list 100 permit ip host 64.240.108.0 host 255.255.255.0
access-list 100 permit ip host 64.240.109.0 host 255.255.255.0
access-list 100 permit ip host 199.217.73.0 host 255.255.255.0
access-list 100 permit ip host 206.129.32.0 host 255.255.255.0
access-list 100 permit ip host 207.138.224.0 host 255.255.255.0
access-list 100 permit ip host 207.138.233.0 host 255.255.255.0
access-list 100 permit ip host 207.149.12.0 host 255.255.255.0
access-list 100 permit ip host 209.102.33.0 host 255.255.255.0
access-list 100 permit ip host 209.102.32.0 host 255.255.255.0
access-list 150 permit ip 207.138.224.0 0.0.0.255 any
access-list 150 permit ip 64.240.108.0 0.0.0.255 any
access-list 150 permit ip 64.240.109.0 0.0.0.255 any
access-list 150 permit ip 199.217.73.0 0.0.0.255 any
access-list 150 permit ip 206.129.32.0 0.0.0.255 any
access-list 150 permit ip 207.138.233.0 0.0.0.255 any
access-list 150 permit ip 207.149.12.0 0.0.0.255 any
access-list 150 permit ip 209.102.32.0 0.0.0.255 any
access-list 150 permit ip 209.102.33.0 0.0.0.255 any
access-list 198 permit ip host 207.138.233.0 host 255.255.255.0
access-list 198 permit ip host 207.149.12.0 host 255.255.255.0
access-list 198 permit ip host 209.102.32.0 host 255.255.255.0
access-list 199 permit ip host 64.240.108.0 host 255.255.255.0
access-list 199 permit ip host 64.240.109.0 host 255.255.255.0
access-list 199 permit ip host 199.217.73.0 host 255.255.255.0
access-list 199 permit ip host 206.129.32.0 host 255.255.255.0
access-list 199 permit ip host 207.138.224.0 host 255.255.255.0
access-list 199 permit ip host 209.102.33.0 host 255.255.255.0
route-map SAVVIS permit 10
match as-path 112
set local-preference 100
route-map PREFERGLBL permit 10
match as-path 2
set local-preference 150
route-map PREFERGLBL permit 20
route-map FROM-INTERNAP permit 10
match community 10
set local-preference 400
set community none
route-map FROM-INTERNAP permit 20
match as-path 50
set local-preference 160
set community none
route-map TO-INTERNAP permit 10
match ip address 100
set as-path prepend 13853 13853 13853 13853 13853 13853 13853 13853 13853 13853
route-map TO-INTERNAP permit 20
route-map Globalex permit 10
match as-path 111
set local-preference 80
route-map MAP1 permit 10
match ip address 199
route-map MAP1 permit 20
route-map MAP3 permit 10
match ip address 110
Silver
Re: BGP config help
Mitchel,
You're traffic leaving out the T1's looks to be due to your statics to default pointing at the T1 next-hops and only one (4th one) points out the Internap exit point.
You're traffic coming back may be coming back over the T1's due to your route-map TO-INTERNAP. It is only matching traffic in ACL 100 but if this is most of your address space then prepending that many PATHS to your AS path will keep most all traffic from entering this link destined to the address space defined in ACL 100.
I only briefly went over your configs so I might have missed something but I hope this helps,
Don
Re: BGP config help
Thanks Don, I will try removing the statics not needed. Also the ACL 100 is all of my address space. and I am prepending it 10 times. I just got of the phone with Internap and they do some funky stuff to preferances that could overide prepends. I wish I new more about BGP and could clean up the mess I have have inherited. Anyway I'll keep at it. Can you or anyone point to a referance on regular expressions, like this, ip as-path access-list 1 permit ^$.
thanks againg,
Mitchel
Silver
Re: BGP config help
Mitchel,
BGP takes shortest AS path as first choice of route so your prepended routes with +10 AS path will look very bad as a routing decision. I wuold recommend you remove this and you might find your traffic comes back through the DS3 as you want. I would surely consult with your ISP though for sure.
Here is a link on regular expressions.
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1831/products_command_reference_chapter09186a00800ca655.html
Hope that helps,
Don
Re: BGP config help
Don, the route with the prepends is the one I don't want traffic to use. So I would think removing it would only make the situation worse. I removed the static routes but that had the effect of sending the traffic out over the Internap circuit, not the DS3. I am hoping to get some suggestions from Internap.
Mitchel
193
