Webcast-Catalyst9k
BGP configuration problem on cisco 1601 with 11.03
I am having problem to configure BGP routing protocol
on Cisco 1601 router
I have no option for configuration of BGP routing protocol in global configuration mode.
I am wondering whether I can do that on 1601 router
or I have to upgrade with specific IOS version.
Amir
1 REPLY
Re: BGP configuration problem on cisco 1601 with 11.03
Amir,
I had the same problem with a 1720 a while back. I went to the software center and downloaded an "IP Plus" version. Problem solved. Just for future reference, here is the link to the feature navigator (FN):
http://www.cisco.com/cgi-bin/Support/FeatureNav/FN.pl
Notice that you can select BGP and then your platform. When you select the "Feature Set" drop down menu, it shows you all the IOS that will work.
172
