BGP Filter Question
Hi All, I'm new to BGP and I have a question regarding a config. in my internet router. we're running BGP via 2 ISPs but our hardware is just 2600 with 64MB memory.An access filter was implemented for this via the config below.
ip as-path access-list 86 permit ^$
ip as-path access-list 86 permit ^...$
ip as-path access-list 86 permit ^....$
ip as-path access-list 86 permit ^.....$
ip as-path access-list 86 permit ^......$
ip as-path access-list 86 permit ^.......$
ip as-path access-list 86 permit ^........$
ip as-path access-list 86 permit ^.........$
ip as-path access-list 86 permit ^..........$
ip as-path access-list 86 deny .*
router bgp xxxx
neighbor xxx.xxx.xxx.xxx filter-list 86 in
I have no clear idea unto what this filter does,
Can anybody explain this to me. Any input will be very much appreciated.
Bronze
Re: BGP Filter Question
This filter does not make sence for me.
The ^ matches the beginning of the input string. Then you got the dots (.) which matches any character including the space. The $ matches the end
So you filterlist will basically match all the AS's up to 10 charakters. So i do not see what you intend to filter with this list.
Here a link to reg ex. for bgp. Hopefully this will help you.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7e6.html
Roger
Looks to me like they are matching the number of Autonomous Sytem numbers in the AS_PATH attribute of incoming routes.
Example:
would match any route with 3 AS numbers in its AS_PATH attribute.
What you did not include is what action is taken on these matches. I would assume there is another configuration section that sets LOCAL_PREF or uses some other method to influence outbound traffic. For example, any route with 3 AS numbers in its path attribute prefer ISP1, 4 AS numbers prefer ISP2.
Perhaps something like this would make the intent of the access list more clear.
ip as-path access-list 86 permit ^[0-9]*$
ip as-path access-list 86 permit ^[0-9]* ^[0-9]*$
-Rob
Gold
I think it's just a malformed as path access list.... Each dot matches any single character, so it's not really an AS match, but rather a character match. So, if you have this:
permit ^...$
That means to match beginning of string, three characters, and then end of string. So, this would match ^100$, but not ^1000$, and not ^10$, so it would only match as' of three digits.
permit ^.....$
Would match ^10000$ or ^10 11$. I'm not certain why you'd want to match this way, the as path filter you've given above is much better, if you take the caret out of the middle:
permit ^[0-9]* [0-9]*$
Would match any as path of two AS', etc.
Russ.W
104
