BGP MIB Value for Current Total BGP Routes From Peer
My backup service provider recently made a mistake which meant that our routes were advertised by them, but that we stopped receiving any Internet routes. In other words BGP was established, we could send routes to the Provider, and could not receive any routes from them (they accidentally applied a deny any route-map).
I would like to protect against this in the future by monitoring a MIB value, and checking whether it drops under a threshold (e.g. 100,000 routes from that peer). However, I can't find an appropriate MIB value, does anyone know of one please?
The MIB values I have found (given below) refer to update packets, and not the total number of routes, which is not what I want. These are:
Object bgpPeerOutTotalMessages OID 1.3.6.1.2.1.15.3.1.13
Object bgpPeerInTotalMessages OID 1.3.6.1.2.1.15.3.1.12
Object bgpPeerOutUpdates OID
1.3.6.1.2.1.15.3.1.11
Object bgpPeerInUpdates OID
1.3.6.1.2.1.15.3.1.10
Ian
1 REPLY
Silver
Re: BGP MIB Value for Current Total BGP Routes From Peer
not sure idf there is one for total prefixes
you can look at http://www.cisco.com/cgi-bin/Support/Mibbrowser/unity.pl?tab=3
this can help you
you may have to use 1.3.6.1.2.1.15.3.1.2 and massage it
183
