BGP Neighbor please help
I have a configuration on BGP that requires for 5 Neighbors 4 locally (same switch) and on that is at the end of a serial link, my question is does the neighbor need to directly connected or can I route the BGP information across the serial link and is thier any special config I need to put in either the serial routers or my BGP routers to make this possible.
Many thanks
Ian
Re: BGP Neighbor please help
iBGP does not require the peers to be directly connected interface.
eBGP are usually on directly connected interface. If you want to establish a eBGP seesion on a non directly connected interface, you need to use the "nei x.x.x.x ebgp-multihop" command. You might also need to specify the source address for the BGP session with the "nei x.x.x.x update-source " command.
Let me know if this answer your question.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Many thanks I will give it a go and let you know
408
