BGP peer-group questions
Hi, is it possible to reference a peer-group as defined under the general BGP configuration in the address-family configuration e.g.
router bgp 1
neighbor PEER peer-group
neighbor PEER remote-as 1
neighbor 1.1.1.1 peer-group PEER
neighbor 1.1.1.2 peer-group PEER
no auto-summary
address-family vpnv4
neighbor PEER activate
neighbor PEER send-community extended
Second question is whether I can define the members of the peer-group as route-reflector-client ?? e.g.
router bgp 1
neighbor PEER route-reflector-client
Thanks a lot,
Adam
alacoba@netstarnetworks.com
Gold
Re: BGP peer-group questions
Yes, you should be able to do this, as long as the neighbors in the peer group are all internal neighbors. I only tried it with the remote as command attached to the peer group.
Russ.W
Thanks for the reply. Was after a sanity check before trying on live equipment.
Cheers
Adam
123
