BGP problem
i've 2 routers:
----------------------------A------------------------
interface Ethernet0
ip address A.B.C.202 255.255.255.248
interface Serial0
description INTERNET
bandwidth 64
no ip address
encapsulation frame-relay
frame-relay lmi-type cisco
interface Serial0.1 point-to-point
bandwidth 64
ip address 192.168.1.77 255.255.255.252
frame-relay interface-dlci xxx
router bgp 1
bgp log-neighbor-changes
network A.B.C.200 mask 255.255.255.248
neighbor B.C.D.22 remote-as 2
neighbor B.C.D.22 ebgp-multihop 255
neighbor B.C.D.22 update-source Ethernet0
#sh ip bgp sum
BGP router identifier A.B.C.202, local AS number 1
BGP table version is 2, main routing table version 2
1 network entries and 1 paths using 133 bytes of memory
1 BGP path attribute entries using 60 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP activity 2/9 prefixes, 2/1 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
B.C.D..22 4 2 0 0 0 0 0 never Active
--------------------------B-----------------------
interface Serial0/0.1 multipoint
ip address B.C.D.22 255.255.255.252
frame-relay map ip B.C.D.21 xxx CISCO
interface Ethernet0/0
ip address X.Y.Z.1 255.255.255.0
router bgp 2
network X.Y.Z.0
neighbor A.B.C.202 remote-as 1
neighbor A.B.C.202 ebgp-multihop 255
neighbor A.B.C.202 update-source Ethernet0/0
It's from debug-
Jul 14 18:19:10: BGP: reset all neighbors due to User reset
Jul 14 18:19:10: BGP:A.B.C.202 went from Active to Idle
Jul 14 18:19:20: BGP: Import timer expired. Walking from 1 to 1
Jul 14 18:19:30: BGP: A.B.C.202 went from Idle to Active
Jul 14 18:19:30: BGP: A.B.C.202 open active, delay 16575ms
Jul 14 18:19:35: BGP: Performing BGP general scanning
Jul 14 18:19:35: BGP(0): scanning IPv4 Unicast routing tables
Jul 14 18:19:35: BGP: Applying map to find origin for X.Y.Z.0/24
Jul 14 18:19:35: BGP(1): scanning VPNv4 Unicast routing tables
Jul 14 18:19:35: BGP(2): scanning IPv4 Multicast routing tables
Jul 14 18:19:46: BGP: A.B.C.202 open active, local address X.Y.Z.1
Jul 14 18:19:47: BGP: A.B.C.202 open failed: Connection refused by remote host
Where i'm wrong?
  • Other Network Infrastructure Subjects
Silver
Re: BGP problem
DO you have an ACL applied to any of these interfaces ?
Bronze
Re: BGP problem
On rtrb you said update source E0/0. rtra should use that address for the neighbor statements like you did on rtrb.
Re: BGP problem
Thank's all-i found my mistake - i added next at router A-
ip route B.C.D.0 255.255.255.0 serial 0.1 permanent
205
