Community Member
BGP RR and OSPF
Here is what I have setup in the lab and for some reason I don't get BGP reflected routes as best route in the route-reflector-client's routing table. I know it has to do with OSPF. If I use RIP the same routes appear as the best routes. Any ideas as to what am I doing wrong here.
Router#1 (Acts as RR)
router ospf 1
log-adjacency-changes
network 172.16.0.0 0.0.255.255 area 0
router bgp 3
bgp log-neighbor-changes
redistribute ospf 1 match internal external 1 external 2
neighbor 172.16.1.2 remote-as 3 (To Router#1)
neighbor 172.16.1.2 route-reflector-client
neighbor 172.16.10.2 remote-as 3 (To Router#2)
neighbor 172.16.10.2 route-reflector-client
Router#2 (RR-client#1)
interface Loopback100
ip address 172.16.65.1 255.255.255.0
router ospf 1
router bgp 3
neighbor 172.16.1.1 remote-as 3 (To RR)
Router#3 (RR-Client#2)
router ospf 1
network 0.0.0.0 255.255.255.255 area 0
router bgp 3
neighbor 172.16.10.1 remote-as 3 (To RR)
Here is my BGP routing table on RR-Client#2
RR-Client#2 show ip bgp
BGP table version is 31, local router ID is 172.16.10.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*>i172.16.1.0/24 172.16.220.1 0 100 0 ?
*>i172.16.2.254/32 172.16.220.1 0 100 0 ?
*>i172.16.10.0/24 172.16.220.1 0 100 0 ?
*>i172.16.20.0/24 172.16.220.1 0 100 0 ?
--------- * i172.16.65.0/24 172.16.1.2 65 100 0 ?---------------
*>i172.16.100.0/24 172.16.220.1 7 100 0 ?
*>i172.16.220.0/24 172.16.220.1 0 100 0 ?
Everything else is fine but 172.16.65.0/24 route is not selected as the best route when I use OSPF as IGP. This route is originated from RR-Client#1.
I checked the RouterID for BGP and OSPF both matches I am not sure what else to check.
Re: BGP RR and OSPF
could you give a 'sh ip os da x.x.x.x' and a 'sh ip bgp x.x.x.x'
Community Member
Re: BGP RR and OSPF
I thank the route 172.16.65.0/24 appear on RR-Client#2 learned from BGP and ospf has different router id
Community Member
Re: BGP RR and OSPF
I think it depends on the administrative distance because the routing table is dependent of the adm. distance.
ex.
eBGP 20
iBGP 200
OSPF 110
a.s.o
A link to it.
http://www.cisco.com/warp/public/105/21.html
Re: BGP RR and OSPF
I'm sorry to say that it has nothing to do with admi distance.
This could be a synchronization issue due to some router-id issue but we need more info to be sure.
237
