BGP using 2ISPs
Hi all
Currently we are using one ISP for our site. We are planning to add the 2nd ISP for redunancy, so that if ISP#1 fails than ISP #2 takes over.
I have attached the pre-define configuration, please help me if there is any configuration that its not correct.
Thanks.
Router #2 ISP #2 side
interface Fastethernet 2/0
ip address 203.1.254.52. 255.255.255.252
interface Fastethernet 1/0
ip address 66.28.166.3 255.255.255.0
router bgp 26000
no synchronization
bgp log-neighbor-changes
network 66.28.166.0 mask 255.255.255.0
neighbor 66.28.166.1 remote-as 26000
neighbor 203.1.254.52 remote-as 2914
neighbor 203.1.254.52 route-map AS 2200 in
neighbor 203.1.254.52 route-map AS 2200 out
no auto-summary
ip as-path access-list 1 permit ^2200$
access-list 10 permit 66.28.166.0
route-map AS permit 2200
match as-path 1
set local-preference 150
set as-path prepend 26000
Router #1 ISP #1 side
ip address 66.166.26.12 255.255.255.252
interface Fastetherne 1/0
ip address 66.166.26.11 255.255.255.0
router bgp 26000
no synchronization
network 66.166.26.0 mask 255.255.255.0
neighbor 66.28.189.3 remote-as 26000
neighbor 66.166.26.13 remote-as 16000
neighbor 66.166.26.13 route-map AS 16000 in
neighbor 66.166.26.13 route-map AS 16000 out
no auto-summary
ip as-path access-list 1 permit 16000
access-list 10 permit 66.166.26.0
route-map AS permit 16000
match as-path 1
set local-preference 200
match ip address 10
Re: BGP using 2ISPs
ip address 203.1.254.52. 255.255.255.252 - First of all .52 is a bad ip address to be assigned to an interface.........52 is a network address for the mask u have used.....53 and 54 are the only ip address u can assign to router interfaces...
and under BGP configs on router 2
I guess u r trying to peer with AS 2914, which is ur ISP 2. So it should be 203.1.254.53 or 54 (according to your mask /30)
Again, on router 2 "neighbor 66.28.166.1 remote-as 26000 " .....What is 66.28.166.1 ??? Is it ip address of router 1 ??? Looking at the peer statement, it looks like u r trying to peer to an internal neighbor ( IBGP).
There are more similar errors...in both the routers....Again there is a ip address over lap on router 1.
Also 66.166.26.12 /30 assigned to fa2/0 of router 1 is a network address again...
Overall, the configuration looks erroneous....
Re: BGP using 2ISPs
Thank you for your comment. I guess I pasted the wrong config.
Please review this one. Thanks again.
The purpose of this is to have redunancy only (no load sharing etc.) Either one ISP or another.
ip address 204.1.254.82 255.255.255.252
ip address 66.28.189.3 255.255.255.0
router bgp 26254
no synchronization
network 66.28.189.0 mask 255.255.255.0
neighbor 66.28.189.1 remote-as 26254
neighbor 204.1.254.82 remote-as 2914
neighbor 204.1.254.82 route-map AS 2914 in
neighbor 204.1.254.82 route-map AS 2914 out
no auto-summary
ip as-path access-list 1 permit ^2914$
access-list 10 permit 66.28.189.0
route-map AS permit 2914
match as-path 1
match ip address 10
set as-path prepend 26254
ip address 66.28.21.114 255.255.255.252
ip address 66.28.189.1 255.255.255.0
router bgp 26254
no synchronization
neighbor 66.28.189.3 remote-as 26254
neighbor 66.28.21.113 remote-as 16631
neighbor 66.28.21.113 route-map AS 16631 in
neighbor 66.28.21.113 route-map AS 16631 out
no auto-summary
ip as-path access-list 1 permit 16631
route-map AS permit 16631
match as-path 1
match ip address 10
ISP#1-AS 16631
ISP#2-AS 2914
Me-AS 26254
118
