BGP WAN Routing
I am still having some difficulty with a bgp configuration. I have a single router with two SPs. The SPs want to ping their respective interfaces. Echoes appear to work from some Internet locations to one interface, and from other locations to the other interface. For instance, Verizon can ping my router (their interface) from the directly connected router, but not from anywhere else. I can ping the Verizon interface on my router from my Comcast account (on the Internet), but I can't ping my other serial interface (ATT).
I have two default routes (0.0.0.0 0.0.0.0) configured on my router and they both show up in the output of sh ip bgp with an "r" (RIB-failure). I'm wondering if this is causing me an issue. When I removed the Verizon default route statement we lost Internet connectivity.
Here is a partial config:
interface Serial0/0
description ATT
bandwidth 1536
ip address 12.12.12.2 255.255.255.252
no ip unreachables
encapsulation ppp
service-module t1 timeslots 1-24
interface Serial0/1.100 point-to-point
description Verizon
bandwidth 1536
ip address 20.20.20.2 255.255.255.252
no ip unreachables
no cdp enable
frame-relay interface-dlci 100 IETF
router bgp 31818
no synchronization
bgp log-neighbor-changes
network 12.12.248.0 mask 255.255.255.0
timers bgp 30 90
neighbor 12.12.12.1 remote-as 7018
neighbor 12.12.12.1 description ATT Peering
neighbor 12.12.12.1 soft-reconfiguration inbound
neighbor 12.12.12.1 route-map ATT_only in
neighbor 12.12.12.1 route-map localonly out
neighbor 20.20.20.1 remote-as 6995
neighbor 20.20.20.1 description Verizon Peering
neighbor 20.20.20.1 soft-reconfiguration inbound
neighbor 20.20.20.1 route-map Verizon_only in
neighbor 20.20.20.1 route-map localonly out
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 12.12.12.1
ip route 0.0.0.0 0.0.0.0 20.20.20.1
ip as-path access-list 10 permit ^$
ip as-path access-list 20 permit ^1010$
ip as-path access-list 30 permit ^2020$
route-map ATT_only permit 10
match as-path 20
route-map Verizon_only permit 10
match as-path 30
route-map localonly permit 10
match as-path 10
Any suggestions would be appreciated.
dk
1 REPLY
Re: BGP WAN Routing
Most providers will include a default route in their BGP advertisement if you request partial routing table. You shouldn't need to have default static routes configured on your side. This is the reason you are seeing the RIB-Failure message, BGP being unable to install the 0/0 in the RIB given that the static routes ares already installed with a lesser AD.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
153
