BGP with Frame Relay
I have used a Cisco 2600 series router with two T1 connections setup with a shadow line from my ISP. I now also have a frame relay connection to a remote office. I would like to know if the 2600 can handle using the frame connection as a backup route to the internet the same way it currently uses the two T1's. I also have a Cisco 3600 on the frame connection at this time. Any of these can be used for this project. I just would like to know if any of these routers can do the job? The end result should be one T1 connection and 1 frame connection used as a backup route instead of the current configuration of one active T1 and one shadow T1. Thanks for any thoughts. Also, any installation tips would be helpful.
1 REPLY
noc
Re: BGP with Frame Relay
please explain how this has to do with bgp ?
where are you running bgp, and who are speaking to
(isp with the T-1, or both isp with T-1 and over
the frame ?)
how fast is the frame ? can you just use floating static routes ? why bgp ?
192
