bidir multicast not work
Hi all,
when I config bidir multicast,it did not work. The manual said it just use:
ip multicast-routing
ip pim rp-address x.x.x.x bidir
to work and you need not config any thing in the interface. But It did not work. My topology is:
e0-R1--R2--R3--R4--R5-e0
e0 of R1 and R5 join group 224.1.1.1 and rp is R3. Can any body tell me what's wrong?Thank You!
Best Regards
Teru Lei
1 REPLY
Re: bidir multicast not work
Hi Teru Lei.
I think you should add the following command in the general configuration mode:
ip pim bidir-enable
Also, I assume you did "ip pim sparse-mode" on all relevant interfaces of all routers.
You should also put this command and the "ip pim rp-address x.x.x.x bidir" on router 3 (with x.x.x.x being its own ip address).
Hope it will help you,
Boaz.
175
