Community Member
big problem, OSPF?ISDN?Router?
2524(U)----ISDN simulator------2525(U)
|____________FR Switch________|
IP
2524 s0, 192.168.1.24/24
bri0 192.169.9.2/26
2525 se0, 192.168.1.25/24
bri0, 192.169.9.4/26
2524:
router ospf 20
net 192.168.1.0 0.0.0.255 area 0
net 192.169.9.0 0.0.0.63 area 0
after I press Enter, the 2524 reboot. I tried several times, everytime after I press Enter, the router reboot.
the error messages are:
%Software-forced reload
Buffered messages:
%SYS-7-NV_BLOCK_INIT:Initalized the geometry of nvramPassed
.......ethernet0 up........
.......serial 0 up...
%SYS-6-STACKLOW:Stack for process OSPF Router running low, 0/3000
Exception:Il
after that, reboot,
what is the problem like? OSPF? ISDN? Router stack bug?
thanks in advance
VIP Purple
Re: big problem, OSPF?ISDN?Router?
what is your IOS version ? Might be a bug indeed...
GP
Bronze
This is an internal software error. Cisco's documentation reads:
%SYS-6-STACKLOW : Stack for [chars] [chars] running low, [dec]/[dec]
Explanation An internal software error has occurred.
Recommended Action If this message recurs, copy the error message exactly as it appears on the console or in the system log, contact your Cisco technical support representative, and provide the representative with the gathered information.
Here is a link to the documentation.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122sup/122sems/semsvol2/emfsys.htm#112683
Good luck.
Mark
209
