Community Member
Binding dialers to specific BRI using a single pool
I have a dialer pool with 4 members (BRI0/0, BRI0/1..) and 4 dialer profiles (dialer1,dialer2...).
I would like to configure the router in a way that EVERY DIALER HAS ITS OWN PREFERRED BRI but can use other bri if necessary.
Dialer1 should use bri0/1, Dialer2 bri0/2, but both could also use bri0/4 in emergency.
"dialer pool-member priority" is not useful for this purpose because it simply gives a higher priority to a member of the pool (bri) no matter which is the dialer requesting it.
Any suggestion or advice?
Community Member
Re: Binding dialers to specific BRI using a single pool
take dialer1, dialer2 static routing default AD value for routing.
configure dialer3, dialer4 on bri 0/4 to locations where dia1, dia2 has been configured. give static routing Administrative distance (AD) value 10 for these routes ( dia3 and dia4).
remote end ...
dialer 0 to your end bri 0/1
dialer 1 to your end bri 0/4
dialer 0 to your end bri 0/2
I think your prob. might be solved.
Community Member
Thank you for your answer. I am a bit confused though.
Do you mean that I must define 4 different dialers each with his BRI and AD (Administrative distance not metric?) for each destination? This would result in 16 dialer definitions... Am I missing something? If so, can you further explain your suggestion? An example would be great indeed!
Silver
Each BRI can be a member of multiple pools, so simply define four pools and assign each BRI to all four, weighting each as desired for the dialer using that particular pool.
Good luck and have fun!
Vincent C Jones
www.networkingunlimited.com
Community Member
I hoped there way to avoid the 4 pools. Anyway that's not a problem. Thanks for your reply.
84
