Webcast-Catalyst9k
blocking https traffic... help
Hello all,
Some of the higher ups are wanting to block some secure webmail traffic and were asking if Cisco had this option.
The only way I can think of is QoS Policy Based Routing... ? Is this correct?
And if so, what would be a basic setup for this scenrio. Like if I wanted to block 443 traffic from a specific subnet range?
Also, anyone know of a link that gives me the rundown on how to setup Policy Based Routing? Like what each step is for...
I've seen a couple threads about this, but the whole setup was kind of obscure to me...
Thanx in advance
1 ACCEPTED SOLUTION
Bronze
Re: blocking https traffic... help
Hello Scott,
I am thinking is it not possible in your scenario to simply block TCP port 443 (HTTPS) from accessing the subnet by using an extended access list :
Let's say you want to block HTTPS traffic from subnet 192.168.1.0/24, you could configure an access list as following:
access-list 101 deny tcp any 192.168.1.0 0.0.0.255 eq 443
access-list 101 deny 192.168.1.0 0.0.0.255 any eq 443
access-list 101 permit ip any any
and apply this access to your local interface, e.g.:
interface FastEthernet0/0
ip access-group 101 in
Does that make sense ?
Nethelper
Bronze
Hello Scott,
Nethelper
Hello Nethelper,
Yes, the extended ACL does make sense. I don't know why I was thinking narrow for Group Policy. I believe this would work.
The company is wanting to block Gmail (abusing chat) and at it's current state, the normal HTTP is blocked via a Software Filter, but HTTPS is still accessable.
Thanks for the reply.
BTW, when is the ideal time to use Policy Routing? Just for load balancing or preferred path type stuff?
200
