BoD over serial links
hello
if i have 2 routers connected through 2 WAN links: PPP and FR.
is it possible to configure the 2 routers in this manner:
use PPP link for routing , if 80% of PPP link is busy than use FR link in addition to PPP to send the data .
how can we configure it?
thx
Silver
Re: BoD over serial links
You could configure the FR link as a backup interface for the PPP link and then use the backup load command to activate the FR link when the PPP link is at 80%:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fdial_c/fnsprt6/dcdbaks.htm#xtocid9
do u mean it is possible to back up an interface with an other that is not dial one !
i've thought we could only back up a PPP link with a dial interface.
in my exactly case, i would like to activate a low speed PPP link when 80% of the FR link is full.
Silver
No you can also use the backup interface command and backup load commands on normal serial lines not just dial lines.
98
