Bonding Ts between 7206 and 2500
I need to bond 2 T1 circuits between a 7206 router on one end and a 2500 router on the other.
I have no problem defining the serial interfaces and bonding them together under a multilink-group ID - but I can't see how to do this on the 2500. Here is a sho ver for both end:
Cisco 7206
IOS (tm) 7200 Software (C7200-IS-M), Version 12.0(5)XE6, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC:Home:SW:IOS:Specials for info
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Thu 30-Dec-99 10:22 by htseng
Image text-base: 0x60008900, data-base: 0x613AE000
ROM: System Bootstrap, Version 12.0(19990210:195103) [12.0XE 105], DEVELOPMENT SOFTWARE
BOOTFLASH: 7200 Software (C7200-BOOT-M), Version 12.0(2)XE2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Ilitch7206 uptime is 1 hour, 1 minute
System returned to ROM by bus error at PC 0x0, address 0x0 at 10:04:32 eastern Mon Apr 5 2004
System restarted at 10:06:05 eastern Mon Apr 5 2004
System image file is "slot0:c7200-is-mz.120-5.XE6"
cisco 7206VXR (NPE300) processor with 122880K/40960K bytes of memory.
R7000 CPU at 262Mhz, Implementation 39, Rev 1.0, 256KB L2, 2048KB L3 Cache
6 slot VXR midplane, Version 2.0
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
8 Serial network interface(s)
8 Channelized T1/PRI port(s)
125K bytes of non-volatile configuration memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
4096K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x102
Cisco 2500
IOS (tm) 2500 Software (C2500-D-L), Version 12.0(6), RELEASE SOFTWARE (fc1)
Compiled Tue 10-Aug-99 23:52 by phanguye
Image text-base: 0x030382E0, data-base: 0x00001000
ROM: System Bootstrap, Version 5.2(8a), RELEASE SOFTWARE
BOOTFLASH: 3000 Bootstrap Software (IGS-RXBOOT), Version 10.2(8a), RELEASE SOFTWARE (fc1)
JLA_to_Fox uptime is 24 weeks, 6 days, 4 hours, 43 minutes
System restarted by power-on at 06:22:54 eastern Tue Oct 14 2003
System image file is "flash:c2500_i_j_m_12-1.bin"
cisco 2500 (68030) processor (revision E) with 16384K/2048K bytes of memory.
Processor board ID 02955553, with hardware revision 00000000
Bridging software.
1 Ethernet/IEEE 802.3 interface(s)
1 Token Ring/IEEE 802.5 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read ONLY)
I don't see a way to define Multilink on the 2500.
Am I way out of luck here??
Thanks.
1 REPLY
Re: Bonding Ts between 7206 and 2500
Multilink does work on the 2500's, I've done it before.
Where exactly is your problem:
A. Define your virtual interface (interface virtual-template)
B. Adding "ppp multilink" to your physical interfaces
Ron
149
