Community Member
Boot load upgrade for 7200VXR
The Cisco 7206 I'm using is running an older version boot load. Where can I download the latest bootcode from and also what is the procedure for upgrading the boot code of this router.
CISCO1#show ver
IOS (tm) 7200 Software (C7200-IS-M), Version 12.2(3b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Fri 26-Oct-01 00:31 by pwade
Image text-base: 0x600089C0, data-base: 0x61362000
ROM: System Bootstrap, Version 12.1(20000710:044039) [nlaw-121E_npeb 117], DEVELOPMENT SOFTWARE BOOTLDR: 7200 Software (C7200-BOOT-M), Version 12.0(13)S, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
CISCO1 uptime is 2 weeks, 1 day, 19 hours, 5 minutes
System restarted at 17:39:57 utc Tue Jul 23 2002
System image file is "sup-slot0:/c7200-is-mz.122-3b.bin"
cisco 7206VXR (NPE400) processor (revision A) with 114688K/16384K bytes of memor
y.
Processor board ID 23664918
R7000 CPU at 350Mhz, Implementation 39, Rev 3.2, 256KB L2, 4096KB L3 Cache
6 slot VXR midplane, Version 2.3
Last reset from power-on
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
8 FastEthernet/IEEE 802.3 interface(s)
16 Serial network interface(s)
8 Channelized E1/PRI port(s)
8 Channelized T1/PRI port(s)
125K bytes of non-volatile configuration memory.
46976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
4096K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x102
1 REPLY
Silver
Re: Boot load upgrade for 7200VXR
Boot code can be found in the software center on the CCO (www.cisco.com) site.
The following link will take you to the 12.2 Boot images.
http://cco/cgi-bin/Software/Iosplanner/Planner-tool/iosplanner.cgi?get_crypto=&data_from=&hardware_name=7200&software_name=BOOT%20IMAGE%20%28ON%20I%2FO%20CARD%20W%2FGE%20OR%202FE%2FE%29&release_name=&majorRel=12.2&state=:HW:SW&type=
Hope this helps,
Don
107
