10-10-2003 03:36 AM - edited 03-02-2019 10:56 AM
I have test router 1603 and i try to boot using image from tftp - in config i have
boot system tftp://A.B.C.D/c1600-y-l.121-2b.bin
after reload i see message on console -
Loading tftp://A.B.C.D/c1600-y-l.121-2b.bin ... [timed out]
From sniffer i get message-
A.B.C.F -> BROADCAST TFTP Read "tftp://A.B.C.D/c1600-y-l.121-2b.bin" (octet)
A.B.C.D -> A.B.C.F TFTP Error: file not found
But c1600-y-l.121-2b.bin exactly at TFTP server
Also i can made next from router
#copy run tftp://A.B.C.D/run
Where i'm wrong?
10-10-2003 04:56 AM
what tftp server are you using, look at its logs, should give you same message you see with sniffer, make sure root directory of tftp server is correct, if cisco's tftp server go under options. you could try a copy start tftp to the tftp server and see which directory it goes in by default.
10-12-2003 10:18 PM
I found my mistake!
When i wrote next -
#boot system tftp c1600-y-l.121-2b.bin A.B.C.D
router booted image from TFTP server.
