Community Member
Bootflash problem.
I am using Catalyst 4840G switch.
I tried installing IOS in the switch from the hyperterminal using Xmodem but it is giving an error.
The error displayed "Remote system Not response"
If I use Xmodem from Rommode it is still unable to copy the IOS.Is it the problem with the Flash card.
Can someone help me out with this issue.
1 REPLY
Silver
Re: Bootflash problem.
Please enable "xmodem" protocol transfer from hyperterminal AFTER issuing the xmodem command. Change to higher baud rate. Some cases, it could be a hardware problem also. Hope the following link helps...
http://www.cisco.com/warp/public/130/xmodem_generic.html
105
