Webcast-Catalyst9k
booting problem in 3745 router
Hii..
I m facing problem in cisco3745 multiaccess router.when i boot the router i get the garbage type of char.from console terminal.plz find the attachment.
Plz guide me wt is the problem and hw to resolve that.
Re: booting problem in 3745 router
does your router keeps on booting with garbage characters displayed ? do you get any error message on the console ?
there is no error message but while preseeing the enter key its give character only.
but there is no error message..
manoj
enter ROM monitor mode by reloading the router and entering the Break key sequence
on ROMMON promt enter below commands:
rommon > dir flash:
It will give you the IOS file on your router with which it has to boot.
Then load a system image using the boot ROM monitor command.
rommon > boot flash:[filename]
[filename] - you have got from dir flash: command.
see if it helps and let me know with the results ...
Check the hyper terminal speed be sure it s 9600.
if its right then check the console cable ,did you made it by yourself or its a blue cable (standard console cable).
I had like this problem i found the error was from cable i changed it to a standard rollover cable i mean original cisco console cable.
Thanks.
Hope usefull.
Hii
after doing the hyper terminal speed 11200, im getting reply in console terminal.
is that possible??
check console port configuration on your router. looks like con0 has configured for 11200 like below:
Router(config)line con0
Router(config-if)speed 11200
302
