Webcast-Catalyst9k
booting problem
i have cisco 2000 router and its not booting at all
i mean the router> prompt doesnot comeup at all
can somebody help me please asap.
Re: booting problem
Do you have LEDs (interface) on ? Did you check the cables/connectors used to access the router ?? Do you see any messages on the console ?
Re: booting problem
What type router is that? 2500, 2600
How are you connecting to the router (console, Telnet)?.
If is console, you may have problems with your setting.
Reza
104
