BRI dial between Ascend Max and 800/1600 series
Anyone know of dial probs between these two platforms? Don't know the Ascend platform but I can find out easily enough if necessary.
Dialing from the Ascend to the the 801/1600 with WIC1-B-S/T is fine but from the Cisco kit to the Ascend is not playing. On PPP and Q931/Q921 debug it appears that the far end is sending a call TERM REQ to which the Cisco router is rightly responding with an ACK. Tried both PAP and CHAP with the same result!!
Following is the debug:
Feb 22 09:18:45.223 GMT: BR0:1 LCP: I TERMREQ [Open] id 3 len 4
Feb 22 09:18:45.231 GMT: BR0:1 LCP: O TERMACK [Open] id 3 len 4
Feb 22 09:18:45.239 GMT: BR0:1 PPP: Phase is TERMINATING [0 sess, 1 load]
Feb 22 09:18:46.235: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0:1, cha
nged state to down
Feb 22 09:18:46.319 GMT: BR0:1 IPCP: TIMEout: State Closed
Feb 22 09:18:47.247 GMT: BR0:1 LCP: TIMEout: State TERMsent
Feb 22 09:18:47.247 GMT: BR0:1 LCP: State is Closed
Feb 22 09:18:47.247 GMT: BR0:1 PPP: Phase is DOWN [0 sess, 0 load]
Feb 22 09:18:47.255 GMT: BR0:1 PPP: Phase is ESTABLISHING, Passive Open [0 sess,
0 load]
Feb 22 09:18:47.255 GMT: BR0:1 LCP: State is Listen
Feb 22 09:18:47.291: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 01132
131152 00c0.7b7b.9a44
Feb 22 09:18:47.295: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from 011
32131152 00c0.7b7b.9a44, call lasted 3 seconds
Feb 22 09:18:47.323 GMT: ISDN BR0: TX -> INFOc sapi=0 tei=116 ns=30 nr=31 i=0x08
015A4508028090
Feb 22 09:18:47.331 GMT: DISCONNECT pd = 8 callref = 0x5A
Feb 22 09:18:47.335 GMT: Cause i = 0x8090 - Normal call clearing
If anyone knows of anything I'd appreciate it, before I raise a TAC case. Note that it says normal call clearing at 09:18:47.335 GMT!!
Many Thanks
Ali
Re: BRI dial between Ascend Max and 800/1600 series
Forgot to mention that authentication passes OK
Cheers
Ali
Got it -
FYI, the Ascend Max doesn't support bidirectional CHAP
103
