BRI to PRI and PRI to BRI
I know that ISDN-BRI can dial-up (initiate a call/connection) to ISDN-PRI. My question is, thus ISDN-PRI can be configured to dial-up to ISDN-BRI?
1 ISDN-PRI 30 channel module dialing to 15 ISDN-BRI? Any sample or links to sample configuration?
1 REPLY
Bronze
Re: BRI to PRI and PRI to BRI
Sure, why not.
The configuration depens a bit on what you want exactly and what is on the other side but here's an example:
username REMOTE1 password PASS1
interface Serial0/0:15
no ip address
encapsulation ppp
no logging event link-status
dialer pool-member 1
isdn switch-type primary-net5
no cdp enable
ppp authentication chap
ppp chap hostname CENTRAL
interface Dialer1
bandwidth 64
ip unnumbered FastEthernet0/0
encapsulation ppp
dialer pool 1
dialer remote-name REMOTE1
dialer string 5551234
dialer-group 1
no cdp enable
!etc. (one Dialer interface per destination)
dialer-list 1 protocol ip list 100
access-list 100 deny udp any any eq rip
access-list 100 permit ip any any
You can customize the Dialers in various ways, e.g.
ppp authentication chap callin
to prevent that the router dialing out requests authentication from the BRI router.
ppp chap hostname ALTERNATIVENAME
to change the name the routers presents itself as in ppp,
ppp authentication pap callin
ppp pap sent-username USER password PASS
to use pap authentication instead of CHAP,
etc.
If you need specific help, let us know.
BTW, there is no limit of 15 destinations, you can define more Dialer interfaces and the router will be able to support 30 simultaneous calls to different destinations.
hth
Herbert
160
