BRI to PRI basic-net5 with dialer interfaces for recieving calls
I'm currently migrating all my BRI interfaces to an E1/PRI interface, remote offices currently dial into my 3640 via a bri int to bri int, but for management and troubleshooting purposes I would like to set them up as BRI Interface to PRI Dialer interface.
Could anyone advise on the best way to configure the router so different remote sites dial into different PRI dialer interface. (E.G. remote site 1 connects to dialer1 and remote site 2 connects to dialer 2)
Re: BRI to PRI basic-net5 with dialer interfaces for recieving c
Here is a sample config for the central (PRI router) set up with dialer profiles:
controller E1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface Serial1/0:23
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type primary-5ess
no peer default ip address
no fair-queue
ppp authentication chap
interface Dialer1
description backup link for U.K.
ip address 172.20.1.1 255.255.255.0
encapsulation ppp
dialer pool 1
dialer remote-name isdn_red_rtr
dialer idle-timeout 300
dialer load-threshold 2 either
dialer-group 1
no fair-queue
ppp multilink
interface Dialer2
description backup link for mass
ip address 172.20.2.1 255.255.255.0
encapsulation ppp
dialer pool 1
dialer remote-name mass_red_rtr
dialer-group 1
ppp multilink
interface Dialer3
description backup link for texas
ip address 10.99.1.49 255.255.255.252
encapsulation ppp
dialer pool 1
dialer remote-name texas_red_rtr
dialer-group 1
ppp multilink
interface Dialer4
description ISDN backup link for ohio
ip address 10.99.1.54 255.255.255.252
encapsulation ppp
dialer pool 1
dialer remote-name ohio_red_rtr
dialer-group 1
ppp multilink
dialer-list 1 protocol ip permit
Use dialer string command in dialer interface if you want your PRI router to dial out to remotes.
Thanks... I just thought there would be more to it... like assigning multiple pri-group timeslots as you can do with channel-group timeslots.
pretty easy to do!
235
