BRI to PRI Connectivity
We want to do a connectivity from a BRI on an 1603R to a 3600 router installed with a PRI interface card. There are a number of problems:
a) We want to use unnumbered interfaces on both sides. This seems to be impossible. If the PRI receives more than 1 call, the system drops the first BRI call and takes over the next one.
b) The above has somehow worked, but we have to define static IP, BUT this is not what we need.
c) Because we have to use static IP's OSPF cannot be put in real action.
Anybody knows how to do the unnumbered case ? If needed I can provide the configuration files. Is there a bug ?
Bronze
Re: BRI to PRI Connectivity
This should work. Can you post the pri interface, interface group, interface dialer, etc. portions of your config on the 3600?
I post the 2 profiles.
CISCO 3660 with PRI ISDN (central)
CISCO ROUTER 3660 FOR ISDN CONNECTIONS
Building configuration...
Current configuration : 1721 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname rnnic249
logging rate-limit console 10 except errors
enable secret 5 $1$6OFL$jfGhAq1BaedIOQMGZDJfX0
enable password rnnic208cs
username cisco3660 password 0 cisco3660
username ciscopri password 0 ciscopri
username ciscopri146 password 0 ciscopri146
username ciscobri password 0 ciscobri
username ciscopri129 password 0 ciscopri129
username ciscopri227 password 0 ciscopri227
memory-size iomem 15
ip subnet-zero
no ip finger
isdn switch-type primary-net5
controller E1 1/0
pri-group timeslots 1-31
controller E1 1/1
shutdown
controller E1 2/0
shutdown
controller E1 2/1
shutdown
controller E1 3/0
shutdown
controller E1 3/1
shutdown
controller E1 4/0
shutdown
controller E1 4/1
shutdown
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 208.250.1.249 255.255.255.0
speed auto
half-duplex
interface Serial1/0:15
ip unnumbered FastEthernet0/1
encapsulation ppp
dialer idle-timeout 1200
dialer-group 1
ppp authentication pap
ppp pap sent-username ciscopri password 7 030752180500315E47
ppp multilink
router ospf 1
log-adjacency-changes
network 208.250.1.0 0.0.0.255 area 0.0.0.2
ip classless
ip route 208.49.193.0 255.255.255.0 Serial1/0:15
ip route 211.32.65.0 255.255.255.0 Serial1/0:15
ip route 211.56.193.0 255.255.255.0 Serial1/0:15
no ip http server
dialer-list 1 protocol ip permit
snmp-server community public RW
line con 0
transport input none
line aux 0
line vty 0 4
password rnnic208
login
end
Remote 1603 using its ISDN S/T for calling (not using the Serial
version 12.0
hostname spe_potamiou
enable secret 5
ip subnet-zero
isdn switch-type basic-net3
interface Ethernet0
ip address 208.49.193.250 255.255.255.0
no ip directed-broadcast
no cdp enable
interface Serial0
no ip address
encapsulation frame-relay
shutdown
no fair-queue
interface Serial0.1 point-to-point
ip unnumbered Ethernet0
frame-relay interface-dlci 20
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
interface Dialer0
encapsulation ppp
ip ospf demand-circuit
dialer remote-name marios
dialer string xxxxxxx
dialer pool 1
dialer-group 1
ppp chap refuse
ppp pap sent-username ciscopri199 password 7 094F471A1A0A0700025D5D73
router ospf 1
network 208.49.193.0 0.0.0.255 area 0.0.0.2
ip classless
ip ospf name-lookup
line con 0
line vty 0 4
password rnnic208
login
end
88
