Bridging between Cisco 2500s
I have two Cisco 2500s with the intent to bridge IP between. I'm using two external CSU/DSUs as line drivers for each end. When all is coupled together(eth0 and s0 on both)and the following router configurations, I'm unable to pass IP traffic, but everything shows up|up.
Router A
Using 565 out of 32762 bytes
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname
enable secret xxxx
ip subnet-zero
no ip finger
interface Ethernet0
ip address 192.168.1.118 255.255.255.0
bridge-group 1
interface Serial0
no ip address
interface Serial1
no ip address
shutdown
ip classless
no ip http server
bridge 1 protocol ieee
end
Router B
Using 499 out of 32762 bytes
version 11.2
no service udp-small-servers
no service tcp-small-servers
hostname
interface Ethernet0
ip address 192.168.1.117 255.255.255.0
bridge-group 1
interface Serial0
no ip address
interface Serial1
no ip address
shutdown
interface TokenRing0
no ip address
shutdown
ip default-gateway 192.168.2.2
no ip classless
What am I missing here? From all I've read it should bridge just fine.
Thanks. -Tom
Re: Bridging between Cisco 2500s
no ip routing
int se 0
bridge-group 1
Thanks.
That was the trick.
-Tom
92
