10-26-2001 09:08 AM - edited 03-01-2019 07:03 PM
One of our sites (site A) used to be connected to another site (site B) via a DSL connection. Over the DSL connection, we bridged DEC to allow an old system to communicate between locations. It worked without any problem. Recently, the DSL connection was no longer offered by the DSL vendor, so we had to switch to a point-to-point T1 line from site A to a third location (site C) that had an existing T1 frame relay connection to site B. (Follow all that so far?)
Here's how it looks:
Site A<------>Site C<----->Site A
PTP T1 FR T1
We are trying to bridge DEC again, but now over these two hops. However, it does not seem to be working. Here's the basic config (relevant to the bridging) that we are using on each router:
Site A
interface Ethernet0/0
bridge-group 1
interface Serial0/0
description ==> PTP T1 to Site C
bridge-group 1
encapsulation ppp
bridge 1 protocol dec
Site B
bridge-group 1
interface Serial0/0.1 point-to-point
description ==> to Site C
encapsulation frame-relay
frame-relay interface-dlci 123
bridge-group 1
Site C
description ==> to Site B
frame-relay interface-dlci 321
bridge-group 1
interface Serial1
description ==> PTP T1 to Site A
bridge-group 1
If we use the command "show bridge 1" on Site A's router, we can see MAC addresses of devices at Site B and vice versa. The RX count on both ends increments, but the TX count does not. However, at Site B (which has other sites connected to it), the other sites' devices' TX count will increment.
We're at a loss as to why this does not work. Could something about the PTP T1 line have something to do with it? Is PPP incapable of handling this bridging correctly? I would think that if that were true, we wouldn't get the MAC addresses passed back and forth.
Any ideas? Please help if you can! Thanks.
10-26-2001 09:30 AM
I noticed that you do not have the ppp encapsualtion on Router C Serial 1.
10-26-2001 09:33 AM
That was an omission on my part. It is actually there.
