Broadcast Counters per interface
1 REPLY
Re: Broadcast Counters per interface
Why is it that I see so many more broadcasts on one interface than on the other interface even though they are connected to each other? any ideas?
4506#sh int g3/3
GigabitEthernet3/3 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 0007.eb97.f478 (bia 0007.eb97.f478)
MTU 150 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex mode, link type is autonegotiation, media type is SX
output flow-control is unsupported, input flow-control is unsupported, 1000Mb/s
input flow-control is off, output flow-control is off
Last input 00:00:06, output never, output hang never
Last clearing of "show interface" counters 00:02:22
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
2026 packets input, 229726 bytes, 0 no buffer
Received 60 broadcasts, 0 runts, 0 giants, 0 throttles
6431 packets output, 1173231 bytes, 0 underruns
0 lost carrier, 0 no carrier
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 000d.2953.8f71 (bia 000d.2953.8f71)
Description: CONNECTION TO 3RD FLR MAIN CLOSET
MTU 1500 bytes, BW 1000000 Kbit, DLY 1000 usec,
Full-duplex, 1000Mb/s
Link type is autonegotiation, media type is SX
output flow-control is off, input flow-control is off
Last input 00:00:01, output 00:00:06, output hang never
Last clearing of "show interface" counters 00:00:37
Output queue :0/40 (size/max)
5 minute ouxtput rate 0 bits/sec, 0 packets/sec
2159 packets input, 297390 bytes, 0 no buffer
Received 880 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 238 multicast, 0 pause input
776 packets output, 80414 bytes, 0 underruns
160
