broadcast storm control in Catalyst 4006?
Sometimes there is a broadcast storm in our network. I have added the broadcast storm control in our Catalyst 2950 switchs, but can not find the same command or function for our Catalyst 4006. Does the broadcast storm control function exist in Cat 4006? If yes, which command can I use?
Thanks.
Jessie
Re: broadcast storm control in Catalyst 4006?
AFAIK there is nothing available for Cat4000 running CatOS now. You can use set port broadcast command on Cat6000.
Good news: I was told that this function should be added to CatOS 7.5.
Milan
Only Per-port unicast flood blocking is supported in 7.5(1)
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/ol_1983.htm#214318
Thanks for your info. I will wait for the new CatOS release.
Jessie
187
