buffer problem?
Why do I lost packets in big buffer and verybig buffer? I still have a lot of free memory.
Any idea?
Router#sh buffer
Buffer elements:
500 in free list (500 max allowed)
6302252 hits, 0 misses, 0 created
Public buffer pools:
Small buffers, 104 bytes (total 200, permanent 200):
199 in free list (20 min, 300 max allowed)
3098752 hits, 0 misses, 0 trims, 0 created
0 failures (0 no memory)
Middle buffers, 600 bytes (total 200, permanent 200):
199 in free list (10 min, 200 max allowed)
518940 hits, 0 misses, 0 trims, 0 created
Big buffers, 1524 bytes (total 200, permanent 200):
200 in free list (5 min, 300 max allowed)
347520 hits, 14853 misses, 3583 trims, 3583 created
8657 failures (1928 no memory)
VeryBig buffers, 4520 bytes (total 30, permanent 30):
30 in free list (0 min, 50 max allowed)
139949 hits, 3658 misses, 265 trims, 265 created
6786 failures (3393 no memory)
Large buffers, 5024 bytes (total 30, permanent 30):
Huge buffers, 18024 bytes (total 0, permanent 0):
0 in free list (0 min, 4 max allowed)
4 hits, 4 misses, 4 trims, 4 created
Interface buffer pools:
Ethernet0 buffers, 1524 bytes (total 32, permanent 32):
8 in free list (0 min, 32 max allowed)
1061 hits, 19107 fallbacks
8 max cache size, 8 in cache
Serial0 buffers, 1524 bytes (total 32, permanent 32):
7 in free list (0 min, 32 max allowed)
675 hits, 18753 fallbacks
8 max cache size, 7 in cache
Serial1 buffers, 1524 bytes (total 32, permanent 32):
6 in free list (0 min, 32 max allowed)
6156 hits, 0 fallbacks
Router#
Router#sh mem
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 5F9DC 7992868 1514864 6478004 6230388 6463940
I/O 800000 2097152 1031656 1065496 96976 1065240
Re: buffer problem?
Fields to worry about here are "no memory " fields in the big and very big buffers. Are these couters increasing? For a stable data flow pattern these values should stop increasing. You can monitor these values for a few days. In case of a remarkable increase you may think about buffer tuning. Link below may help:
http://www.cisco.com/en/US/customer/products/hw/routers/ps133/products_tech_note09186a00800a7b80.shtml
Re: buffer problem?
Try the following buffer changes to see if it helps, you will need to reload the router after you have added the config:
buffer big permanent 260
buffer big min-free 78
buffer big max-free 371
buffer verybig permanent 39
buffer verybig min-free 11
buffer verybig max-free 55
Re: buffer problem?
Hi, kkalaycioglu & rgallagh
Thanks for your replay. I have viewed that web link before I post my question. It’s not really helping me for my problem here.
I have been monitoring my router for the last a few days. Definitely there is no memory leaking and buffer leaking. But I still got "no memory" incrementing for big buffer and very big buffer even I have plenty free memory in the router.
I will adjust the buffer settings and reload the router. Keep monitoring the router for a few days.
My next question is that: If I see some input errors from some of the router interface, is that will cause this buffer “no memory” incrementing?
99
