Bundled E1's using MLPPP
Hi, I need to bundle 2 e1's into a virtual link....I have successfully done this but when I add a secondary ip address on the loopback interface I can't ping the secondary address. sample config from 1 router....the other router is configured the same. I am aslo not getting any ipx routes on the remote router.
On this particular connection I also need to add some summerization statements. Any help or direction to related docs would be welcom.
ip subnet-zero
ip name-server 172.21.0.240
multilink virtual-template 1
ipx routing 00e0.b0e2.4251
clock timezone gmt 0
clock summer-time gtm recurring
interface Loopback0
ip address 12.2.2.1 255.255.255.252 secondary
ip address 172.21.39.193 255.255.255.252
no ip directed-broadcast
ipx network 2002ABCD
interface Ethernet0
ip address 172.21.39.125 255.255.255.192
ip helper-address 172.21.0.240
media-type 10BaseT
ipx network 200244E7
ipx output-gns-filter 1099
interface Ethernet1
description SIMBA Test LAN Segment 10.200.18.0
no ip address
media-type 10BaseT
interface Virtual-Template1
ip unnumbered Loopback0
ipx ppp-client Loopback0
interface Serial0
no ip address
encapsulation ppp
load-interval 30
no fair-queue
clockrate 2000000
ppp multilink
interface Serial1
no ip address
encapsulation ppp
no fair-queue
clockrate 2000000
ppp multilink
Re: Bundled E1's using MLPPP
I am not sure an ip unnumbered will pick up the secondary address. That may be the problem.
Do you need ipx ppp-client or can you put the IPX network there instead? Also, what is your IPX routing protocol?
Steve
Thanks steve,
I removed the loopback interface and added the ip addresses to the virtual-template1 interface and it work OK....I'm not too worried about IPX as we are in the process of removing this from the Network.
Many thanks for your help
cheers
Paul
178
