bundled or loadbalanced Frame Relays
Is it possible to setup two Frame Relay circuits connecting to different CSU/DSU interfaces on a 2621 Router to be load balanced or bundled? We are wanting to use the same IP block but just have twice the bandwidth.
Thanks.
Anonymous
N/A
Re: bundled or loadbalanced Frame Relays
It is possible to load balance in frame relay.
In the following example : two PVCs between Router_A and Router_B. A routing protocol should like OSPF is needed. Depending on the bandwidth either fast switching or Process swiching can be done. If you do process swiching router processor will be overloaded provided the bandwidth is large.
Thanks for the info. Next question is what if the two Frame Relay Circuits come from two different routers? They would both be from UUNet but they might be coming off of different routers or even cards. Also do you know of a white paper for setting up the load balancing.
Thanks for you help.
Anonymous
N/A
To check the load balancing view show interface serial 0 and 1
Router_A --------- Router_B
FR
Interface Serial0
encapsulation frame-relay
bandwidth 128
frame-relay lmi-type ansi
Interface Serial0.101 point-to-point
ip address 10.0.1.1 255.255.255.0
bandwidth 128
frame-relay interface-dlci 101
Interface Serial1
bandwidth 128
Interface Serial1.201 point-to-point
ip address 10.4.2.1 255.255.255.0
bandwidth 128
frame-relay interface-dlci 201
Followup response
The following URL has information on Load balancing
How Does Load-Balancing Work?
http://www.cisco.com/en/US/tech/tk648/tk365/technologies_tech_note09186a0080094820.shtml
http://www.cisco.com/en/US/tech/tk648/tk365/technologies_q_and_a_item09186a008012d8f7.shtml#Q17
How Does Unequal Cost Path Load Balancing (Variance) Work in IGRP and EIGRP?
http://www.cisco.com/en/US/tech/tk648/tk365/technologies_tech_note09186a008009437d.shtml
81
